1 - 19 of 19 Posts
Does anyone know how to remove the grill Volvo badge? I've looked quite extensively but am a little weary of breaking something. <p><br>Oh, and I hope I posted this in the right place, being new and all...
it is in the right place...<p>Are you talking about the VOLVO badge alone or the badge and slash?
I am <b>not</b> positive, but on my s80, I know if you remove it, it will look like crap. You will be able to tell that the slash was there. There is alternatives for the grill, from what I have seen, mostly painting them.<p>Xenophobic (youll see later that this guy is a genious)<br><IMG SRC="http://img117.imageshack.us/img117/4093/p70107654ti.jpg" BORDER="0"><br><IMG SRC="http://img110.imageshack.us/img110/7259/p70107619ls.jpg" BORDER="0"><p>Quick Brick <br><IMG SRC="http://www.msnusers.com/_Secure/0VAAAALYXi9M20JZZJ0w8YguLvWBZ3PmSRpbFGfjmjz!0BPJ3nqj9z2B0mVjOYYSN!kwj9LsPdkczWecTpXzD2Z51ANcIRuTpcWLy0p4YLUuq9Vv!uYHpUK8Ns4X7n5aj/IMG_1781.JPG?dc=4675566756157443860" BORDER="0"><br><IMG SRC="http://www.msnusers.com/_Secure/0VAAAALcX1tM20JZZJ0w8YuGLMVlHaLgG2d4rdaTUh9MI6K1KSxouXngtJmVIfR6xML0duk!xmODLA82NwnRNEH*L0FVWshKrMWSEX0MJiAOjZ2VNWro!kx!IL*Xbl*Ol/IMG_1782.JPG?dc=4675566756214662369" BORDER="0"><br>Hope this helps,<br>"copeland" the "faux R owner"
Like I said, I am not sure about the R's...<p>but the badge/slash can be removed<p><IMG SRC="http://www.msnusers.com/_Secure/0VAAAALUXPtM20JZZJ0w8Ylf0Q9zX*99zdH1Or6QEh6ke6qe1AO*XWCi2ClaDV06qyhKYCWmPG60HPamPgHRF6MYCS5xyxH!21K17yYA1LLfbhe*3Xa9hbzbBKFGZe1NX/IMG_1762.JPG?dc=4675566764259936251" BORDER="0">
Re: Removing grill badge (frogsthatmoo)
Yes, as Copeland correctly stated, you can remove it, but I wouldn't do it permanently. There are 2 big ugly snap features plus a "bellybutton" in the center, left on the grill ... it is not just a grate.<p>To just remove the slash, you could just pull ... I would however suggest removing the grille and helping the little snap tab features disengage from the back.<p>Lastly, if you are asking about removing the Volvo emblem from the slash ... forget it. It is 2 way stickied in there so well I really doubt you would do it with out completely destroying the slash and the emblem in the process. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> . Sorry.
Hey New Kid <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"><p>Post some pics of you caR
Re: Removing grill badge (Quick Brick)
Removing the grill is rather easy and this will be the best way to go. Pulling on the badge is not a good idea. Push the plastic post out from the back of the grill (a screw driver will work fine). <p>Copeland is right though, you can tell that it has been removed. The pattern is disturbed by the mounting points of the emblem. <p>To put the emblem back on, grab an 8mm socket and press the lock washers over the post until tight. You should be able to reuse the lock washers (before I made my mesh grill, I had painted the inside of the V70 grill... I had to repaint, so I reused the washers a couple times without issue.)<p>PS- to remove the grill, there are six plastic clips that hold the top of the bumper on. Just press in the center to pop the clips and remove. Just pull the top of the bumper out enough so you can see the clips that hold the grill in. Use a screwdriver to release the grill from the top clips from behind the bumper. Pull the grill out from the front of the bumper enough to fit a long screwdriver between the grill and nose (careful of your paint, the clips from the grill will rest on the paint, be sure you don't scratch it, masking tape will protect it if you are aprehensive) Release the clips on the bottom with the screwdriver and you're done!
Here's what you would be left with if you tried to "debadge" it...<p><IMG SRC="http://img103.imageshack.us/img103/2857/DSCN1666Medium.jpg" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>New Guy</b> »</i></TD></TR><TR><TD CLASS="quote">Well, does anyone know what an R car looks like without the Volvo badge and slash? </TD></TR></TABLE><br>Yes, look above you <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"><p>As you can see, the "eggcrate" design will show a significant change in a negative way IMO.<p>looks dumb, you can always get a new grille, I think evolve sells one. <A HREF="http://www.evolvecars.com" TARGET="_blank">http://www.evolvecars.com</A> <---YOU can trick your car out cosmetically here. In the words of Paris Hilton, "that's hawt" <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
Re: (StaggRLee)
This was my solution to the pesky branding...<p><IMG SRC="http://img103.imageshack.us/img103/5015/DSCN1691Medium.jpg" BORDER="0"><p><IMG SRC="http://img103.imageshack.us/img103/2035/DSCN1688Medium.jpg" BORDER="0"><p>... but don't go there unless you've got a lot of time and patience.
Awesome Stag!<p>That is what Evolve does I believe.<p>Your car is beyond clean too! I think I can see God in your hoods reflection <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
Re: (Copeland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Copeland</b> »</i></TD></TR><TR><TD CLASS="quote">Awesome Stag!<p>That is what Evolve does I believe.<p>Your car is beyond clean too! I think I can see God in your hoods reflection <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"></TD></TR></TABLE><p>Yes that's an Evolve insert. <p>And I'd never do it again. What a PITA! <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
<IMG SRC="http://www.v70r.com/forums/index.php?act=module&module=gallery&cmd=si&img=180" BORDER="0"> Eventually I want to get a stock r eggcrate that someone removed and try to fix the holes. If anyone has one laying around IM me please<br>DAn<p><A HREF="http://www.v70r.com/forums/index.php?act=module&module=gallery&cmd=si&img=180" TARGET="_blank">http://www.v70r.com/forums/ind...g=180</A><br>if the pic doesn't work click above
Re: (frogsthatmoo)
This is what their cut and clip installation instructions would result in:<p><IMG SRC="http://img103.imageshack.us/img103/1712/DSCN1644Medium.jpg" BORDER="0"><p><IMG SRC="http://img103.imageshack.us/img103/9466/DSCN1648Medium.jpg" BORDER="0">
1 - 19 of 19 Posts
