1 - 12 of 12 Posts
Do I have to pull the dash to remove the black plastic frame over the steering column that surrounds the gauge cluster? I need to pull it to mount my custom external indicator for my Valentine 1.
Make sure you post a picture of the remote mount. I'd like to see it.
this is the rough in, needs to be touched up and then hot glued in. I repainted the V1 unit today and need it to dry before it's mounted. I cut the opening this morning and will post a few shots when its all done.
Where's the mute button on your remote?
It was rewired. The brown and white are for the mute. I hope to run the wires down the center console and mount a small, push button micro switch on the side near the drivers seat. I'm in the process of sourcing a new switch as a can't locate the original.
1 - 12 of 12 Posts
