Tire Car Automotive parking light Wheel Automotive side marker light
Hi all, just bought a pair if these headlight lenses to replace my crazed ones on my 2010 Xc90, has anyone tackled this job before, heard some say you put the whole light assembly in oven to soften old glue to get old lense off.. Any feedback would be really appreciated
2008 XC90 3.2
If you search about installing aftermarket HIDs into halogen housings, I wrote how it is super difficult to remove the lens from the original aged headlight housings. The rubber seal does not get soft and it’s very difficult to cut it out. It would take a Dremel to get the lens seal out, if not more. Think about if the lenses were epoxied on the plastic housing and you had to find a way to remove them. That’s how difficult it will be.
I simply took new aftermarket housing assemblies and was able to “bake” them to soften the seal and it worked for removing the lens. I then installed aftermarket HIDs that I still run today nearly 5 years later.
edit: changed autocorrect deemed to dremel
V70 02/2007 auxiliary heater with all start/stop options Billstein B12 kit Xc90 brakes abl retrofit
i remove the old lenses by cutting them on the edge with an angle-grinder with a very thin cutting disc
Remove the remaining parts by hand..
Never put them in the oven, to avoid the risk of damaging (melting/disform) the housing.
Automotive parking light Automotive lighting Hood Automotive design Automotive tire
Automotive parking light Land vehicle Vehicle Grille Car
Automotive parking light Automotive lighting Grille Motor vehicle Hood
Automotive lighting Hood Vehicle Motor vehicle Automotive design
2008 XC90 3.2
Is that a V70 headlight?
