I have a broken retainer on one of my coil pack plugs, I got some plugs from a wreck but Dont know how to get the pins out of mine to put the new plastic on, I would cut and solder but suspect that may not be a good idea
I had the same issue and picked up a wire terminal tool kit.
Place the tool in the broken connector and pull out the wires and insert back into the new connector.
https://www.amazon.com/Lisle-57750-...keywords=lisle+pin+tool&qid=1570378446&sr=8-1
Or you can try two flat modified paper clips or something else to place in the top and bottom of the connector to free up the pins. Good luck.
edit:
I just checked, you don't have to pick up the entire kit.
This blue terminal tool will do the job.
https://www.amazon.com/Lisle-57780-...isle+terminal+tool+ford&qid=1570394394&sr=8-1
