To tow the vehicle or use it to tow other things?
the volvo accessories catalogue I am looking doesn't have a tow bar for towing the car, so yes to tow other things - e.g. caravan, trailer, etc
With an R-Design, the lower rear skirt is cut out for the hitch. It's not a clean look. I've seen it installed on the 3.2/T6 and this isn't a problem as the skirt sits higher and hitch clears the bottom.
The hitches listed on etrailer.com require no cutting, other than the heat shields under the car that you cant see.
