1 - 19 of 19 Posts
Has anyone used these? Does anyone know what size I need for the exhaust side and for the DP side?<p><A HREF="http://www.remflex.com" TARGET="_blank">http://www.remflex.com</A>/
Re: Remflex gaskets (baxteR)
Dave, you're looking at the 3" pipe diameter with 4 1/8" bolt spacing (2 bolt):<p><A HREF="http://catalog.remflex.com/COLLECTOR_CONNECTOR_Flange_Exhaust_Gasket_p/rf8006.htm" TARGET="_blank">http://catalog.remflex.com/COL...6.htm</A> <p>You could also go this one probably:<br><A HREF="http://catalog.remflex.com/COLLECTOR_CONNECTOR_Flange_Exhaust_Gasket_p/rf8007.htm" TARGET="_blank">http://catalog.remflex.com/COL...7.htm</A><p>Turbo side, you said it's 3 hole? I didn't see anything on their website for turbo to DP that looked like it would fit.
Re: Remflex gaskets (T5 for Life)
I'm thinking maybe this for the turbo side.<p><A HREF="http://catalog.remflex.com/ProductDetails.asp?ProductCode=RF8002" TARGET="_blank">http://catalog.remflex.com/Pro...F8002</A>
Anyone? Tony how did you find out about them?<BR><BR>
<i>Modified by baxteR at 7:14 AM 3-26-2009</i>
I was researching exhaust flange warping and came across their name on several different forums. Both American muscle car guys and import tuners like them.
I IM you. I don't know the correct size for the turbo side of the DP.
Not to jack the thread but could somebody provide the size of the factory catback to DP nuts?
Re: Remflex gaskets (xman03)
That's alright xman jack away, no one else has any idea.
Re: Remflex gaskets (mpdbrown)
I'm supposed to get my flange gasket on Wed. I'll let you guys know if the size I ordered is correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>T5 for Life</b> »</i></TD></TR><TR><TD CLASS="quote">I'm supposed to get my flange gasket on Wed. I'll let you guys know if the size I ordered is correct.</TD></TR></TABLE><p> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
bump<p>The gasket delivery has been delayed until next week for some reason. now expected on 4/06/09.<p>looks like i get more shweeeeeeee at WOT.
Discussion Starter · #14 ·
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>T5 for Life</b> »</i></TD></TR><TR><TD CLASS="quote">bump<p>The gasket delivery has been delayed until next week for some reason. now expected on 4/06/09.<p>looks like i get more shweeeeeeee at WOT.</TD></TR></TABLE><p>They didn't give you a reason?
negative Lord baxteR. I only noticed it when I checked UPS shipping tracker.
<A HREF="http://catalog.remflex.com/COLLECTOR_CONNECTOR_Flange_Exhaust_Gasket_p/rf8006.htm" TARGET="_blank">http://catalog.remflex.com/COL...6.htm</A><p>This is the one I got, and it fits the flange on the stock exhaust I took off. Opening is a bit larger than needed, but it will seel. It's made of this funky graphite stuff, very maleable and compressible. I won't be able to install it until Saturday, but this should solve my problem. I recommend this from step 1 if you're putting an exhaust on your stock downpipe.
This is the solution. Very nice piece of work, even if it's only a gasket. Sealed up the warped flange instantly. May want to get slightly longer bolts though. It compresses a bit, but is still pretty thick.
Any idea if it fits the flange PHUZ had made for downpipes a few years ago?
Re: (chinaonnitrous1)
If it's the "standard" shaped flange and is 3" in diameter, it will fit. Has a 4 1/8" bolt spacing, like the stock exhaust/flange setup.
1 - 19 of 19 Posts
