1 - 11 of 11 Posts
Hello all. I got the first regular maintenance warning light on my wife's XC90. Anyone know how to turn it off or reset manually? Thanks in advance.
Re: Regular maintenance warning light (Inhart)
<br>First off, you need to get the maint done. If taking it to the dealer to get the main then do not<br>reset the light. Let them do it. If you taek it to someone that doent know how to reset<br>the light, then you are taking the car to the wrong place to get it serviced. They should know<br>Volvos.<p>I believe this will clear it... ( I am sure someone will correct me if I am wrong)<p>insert key<br>turn key to first click<br>hold in the ODO button<br>turn key to second click while holding button in<br>maint light will flash a few times<br>let go of button
Re: Regular maintenance warning light (dmd)
Thanks for the quick answer. Okay here is an another question. I took the wife's XC90 to local shop and had an oil change at 7000 miles and now it has 9000 miles. Do you think I still need to take it to dealer. I was going to take it when it will have about 12000 miles.
maybe not this one but the next service interval you should. they repalce the cabin air filters, etc.<p>regular service is every 7500 miles.<br> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
<p>As long as you cover the maint items in the manual, weather you do it or someone else<br>(and you can prove it) then it doesnt matter.... Also, if the person that changed the oil<br>didnt know how to reset it, then you should take it someplace else. They have no idea<br>what needs to be done during the service
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Inhart</b> »</i></TD></TR><TR><TD CLASS="quote">Okay here is an another question. I took the wife's XC90 to local shop and had an oil change at 7000 miles and now it has 9000 miles. Do you think I still need to take it to dealer.</TD></TR></TABLE><p>Sounds like your local Jiffy Lube didn't reset the service light.
Re: Regular maintenance warning light (MagoonR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>MagoonR</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Sounds like your local Jiffy Lube didn't reset the service light.</TD></TR></TABLE><p>No because at the time the warning light wasn't on. I actually thought about go to dealer for service every other time but sounds like I need to go to dealer every time. Thanks all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Inhart</b> »</i></TD></TR><TR><TD CLASS="quote">No because at the time the warning light wasn't on. I actually thought about go to dealer for service every other time but sounds like I need to go to dealer every time. Thanks all</TD></TR></TABLE><p>Ummm..........the lcomputer didn't feel like giving you the light at 7K but does at 9K; perhaps due to your driving situation? IIRC, there is no hard and fast rule that says the light comes on every 7500 miles. Therefore, I deduce that the Jiffy Lube did not reset it. Take a few moments and clear the light yourself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Inhart</b> »</i></TD></TR><TR><TD CLASS="quote"><p>No because at the time the warning light wasn't on. I actually thought about go to dealer for service every other time but sounds like I need to go to dealer every time. Thanks all</TD></TR></TABLE><p>You dont need to go to the dealer, just to a service that knows Volvos and does a complete service<br>for that interval. You can do it yourself also, just keep the receipts for the parts as proof of <br>service for warranty reasons.
thank you very much for the post! the dealership forgot to reset the maintenance light when we took it in, so this saved us a trip to firestone or the volvo dealership.<br>thanks again!!!!
Re: Regular maintenance warning light (volvo4life92)
1. Turn ignition switch to position I. <br>2. Press and hold "day counter reset button". <br>3. Turn ignition to position II. <br>4. Continue holding day counter for about 10 seconds. <br>5. While SRL flashes, release day counter reset button. <br>6. Should hear "beep-beep" to confirm command accepted. <p>Hope this helps.<BR><BR>
<i>Modified by exec at 12:03 AM 7-19-2009</i>
1 - 11 of 11 Posts
