Hello there!
I received the "Chassis Setting Service Required" message on my dash. I pulled over, cycled the key a few times and it cleared however, the message returned after a few more miles. I repeated my pull over & key cycle trick but the message returned shortly after driving again.
Any ideas what is going on and how I can fix it?
Many thanks.
P.S. VIDA showed this:
If Vida show up it, replace the sensor - after you check the wire and connect is right.
S60 R 2004
Clear message then turn wheel all the way to left and right. If the message pops up when turning then clear it again and wiggle sensor cable. It's that accelerometer in middle of the shock. Cable in mine is also going bad and gives code especially on winter.
