1 - 2 of 2 Posts
Hi,<br>Does anyone know the width and thickness of double sided tape needed to refit the door side moldings?<br>Is the lip on the back of the trim wide enough to use 1/2in tape or would 1/4in be a better fit?<br>Is 45mil (1.1mm) tape the correct thickness as I don't want the trim to be sticking out or "give" too much when pressed. There is a thinner 30mil (0.8mm) tape available from 3M<br>Hope someone can help as I'm planning on doing the vinyl wrap thing with my moldings and I need to order my supplies in before I can take anything off.<br>Regards.<br>Mike
Re: Refitting Door Side Molding Question. (mhon)
I believe the thinnest is the best.<br>Use 1/4" top and bottom (1/2" is OK too, won't hurt)
1 - 2 of 2 Posts
