2003 XC90, T6.
Short version:
While changing my timing belt, I removed the computers to get better access. During the process I turned on the ignition and moved it to the Start position. Now, I get Reduced Engine Performance and the last code I was able to retrieve was P1167. Car ran fine before timing belt removal.
How can I clear this? Or does a dealer need to be involved?
More detail:
Before changing the belt, I disconnected the + cables at the underhood fuse box, thinking that it would effectively disconnect the battery (wrong). As mentioned, I had popped out the computers to gain access, since this is simply a stupid job, access-wise.
Since I didn't have an impact wrench for the harmonic balancer nut, I figured I'd try using the breaker-bar-against-the-floor-and-pop-the-starter technique...forgetting that I'd removed the computers. Doh.
I believe this triggered the immobilizer, which I was able to clear using the remote lock+unlock x5 trick.
After I got it buttoned up, I went to start it and got the CEL and Reduced Engine Performance messages. I retrieved the P1167 before my cheap ELM327 device died.
I believe the cam timing is right...I mark the pulleys and old belt, then transfer the marks to the new belt, and everything lined up. (Will do a quickie compression check tomorrow).
Any way to clear this on my own?
The P1167 translates to:
P1167 -- ECM-92CC -- Throttle unit -- Signal too high
P1167 -- ECM-92CD -- Throttle unit -- Signal too low
I do not believe the ETM is faulty, since all was well before my 'fix.'
Any advice on how to clear or diagnose?
Also, the scanner I borrowed (after mine died) won't link...so it's hard for me to get codes now.
TIA...
Administrator
Do you have access to someone with VIDA and a DICE unit near you? That might be able to further diagnose and clear the codes.
I was set to give up and have the vehicle towed to Nordic Motors here in Cincinnati, but Bill the owner called me before I had the tow arranged. He listened to my situation as described above, and recommended that I re-seat the computers - which I did. And which fixed the issue. I feel foolish about this, but maybe this will help someone some day.
I didn't have the computer removal tool, so when disassembling, I unbolted the base plate and removed the perimeter cover. This let me free up the assembly so I could use a short screwdriver, to push the pink plastic wedge clamps toward the front of the car, which eventually released the computers. No biggie, just a little tight for large hands.
On re-installation, I failed to push the plastic wedge clamps all the way and thus didn't fully seat the computers....they appeared to be seated but were not.. Hint: use a small screwdriver, and push the clamps from the front, just at the back side of the headlight. They wiggle-push the computer downwards, and push each plastic wedge again. Repeat.
So...my hat's off to Bill at Nordic Motors, who essentially talked me through this and therefore himself out of a service job...one thing's for sure, I visit him first next time I need something. Excellent stuff.
Administrator
Glad it was an "easy" fix!! Definite shout out to Bill at Nordic Motors!
