1 - 8 of 8 Posts
Discussion Starter #1
What do you guys recommend I use as new fluids on my S60R?
I want to replace transmission and differential fluid any suggestions on what to use?
Also what else should I do at 110k?
Cabin air filter, fuel filter, timing belt, water pump?
Thanks in advance :beer::):beer::thumbup::beer:
Spark plugs.
Might as well add the Angle gear fluid and Collar gear/sleeve inspection.
Hmm massive post around here about that. Thought I had it bookmarked, but I was wrong.
Fuel Filter
Spark Plugs
Coils
Air Filter
Engine Oil
Cabin Filter
Timing Belt
Water Pump
Angle Gear inspection/Collar Sleeve inspection
might want to flush your tranny fluid... not sure if you are MT or AT
there are stickies for just about all of those
Unless your angle gear is leaking heavily and thereby needs a reseal I think its overkill to pull it and inspect the collar sleeve. I'd just change the fluid and leave it at that.
Discussion Starter #6
Thanks guys,
I'm planning on doing the fluids this weekend (assuming weather is decent)
Still need to go out and buy all the supplies
Agreed. Inspection, to me, just lends top a likely leak to form. Since I had my AG replaced under warranty at about 42000 miles, and they resealed it apparently very well (60, 000 miles ago), I'd rather not risk creating a bad seal. Not to mention that I do a ton of highway driving (95%). However, if you're in a lots of city driving, it might be worthwhile.
Guys, dont forget to get the radiator flushed, seems a lot of people forget that during maintenance... remember we have aluminum radiators, which corrode over time and break apart which damages our head gaskets and cause a lot more problems.
110K
1. Timing belt/idler pulley/tensioner if it hasn't already been done
2. Radiator and Brake fluid flush
3. spark plugs (coils too if budget allows, but its a preventative - when it fails, you'll know right away)
4. filters (pending on when you changed them)
5. angle gear & DEM / AOC fluid change
1 - 8 of 8 Posts
