1 - 2 of 2 Posts
When I drive to work I happen to pass a water treatment plant. I will turn on the recirc button to minimize the bad odors that come into the car, but it doesn't seem to do a very good job. I know I'm not crazy because I used to have a Maxima, and when I would drive by that very same spot, I wouldn't get any foul odors into the car. Any ideas on where to look, where to start, or is this just typical S60 behaviour.
If your car is equiped with automatic air qualty sensor, it could be not working properly. The button with ''MAN AUT'', to select recirculation you should press it till you see oragne light it means recir is on. If your clime control is simple just recirculation button then skip this.
Ok so if you suspect its not wotking it could be climate controls module fault, try swaping it with other one and see if problem is stil there.
Also less odors will enter a car if you turn down blower to off (when one orange light is only present instead of green ones)
1 - 2 of 2 Posts
