Where is the low-side fitting located on a 2001 S80 T6?. Does a regular R-134a charge kit work or will I need a special fittings?<p>Thanks<p>
Re: Recharge A/C (Z-Man)
You DO realize if your A/C needs a charge it has a leak somewhere?<br>Cars don't "just need a charge" there's a reason why your A/C doesn't work
Re: Recharge A/C (JRL)
A/Cs can leak very slowly, and maybe he just wants to top it off because it's a VERY hot spring already. True it probably has a leak, but he might as well re-charge it until he can fix it. I thought the low-side was by the radiator.
