http://www-odi.nhtsa.dot.gov/recalls/results.cfm
Make: VOLVO Model: XC60
Model Year: 2012
Manufacturer: VOLVO CARS OF N.A. LLC. Mfr's Report Date: FEB 27, 2012
NHTSA CAMPAIGN ID Number: 12V075000 NHTSA Action Number: N/A
Component: ELECTRICAL SYSTEM:WIRING
Summary:
VOLVO IS RECALLING CERTAIN MODEL YEAR 2012 S60, XC60, S80 AND XC70 VEHICLES MANUFACTURED FROM MAY 16, 2011, THROUGH OCTOBER 6, 2011. IN THESE VEHICLES, THE WIRE HARNESS UNDER THE FRONT SEATS MAY HAVE NOT BEEN ATTACHED PROPERLY TO THE SEAT FRAME. AS A RESULT, WHEN THE SEATS ARE MOVED TO ADJUST THE SEATING POSITION, THE WIRE HARNESS MAY GET PULLED, CAUSING IT TO DISCONNECT.
Consequence:
IN THE EVENT OF CRASH, THE FRONT AND/OR SIDE IMPACT AIR BAGS MAY DEPLOY IMPROPERLY OR NOT AT ALL, INCREASING THE RISK OF INJURY. ALSO, THE LAP BELT PRETENSIONER MAY NOT DEPLOY.
Remedy:
VOLVO WILL NOTIFY OWNERS, AND DEALERS WILL INSPECT AND, IF NECESSARY, SECURE THE SEAT WIRE HARNESS. THIS SERVICE WILL BE PERFORMED FREE OF CHARGE. THE SAFETY RECALL BEGAN ON APRIL 12, 2012. OWNERS MAY CONTACT VOLVO CARS AT 1-800-458-1552.
Notes:
THE VOLVO RECALL CAMPAIGN NUMBER IS 250. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO
HTTP://WWW.SAFERCAR.GOV.
OR;
Model Year: 2012
Manufacturer: VOLVO CARS OF N.A. LLC. Mfr's Report Date: MAR 13, 2012
NHTSA CAMPAIGN ID Number: 12V101000 NHTSA Action Number: N/A
Component: STRUCTURE:BODY
Summary:
VOLVO IS RECALLING CERTAIN MODEL YEAR 2012 S60 AND XC60 PASSENGER VEHICLES. AN INCORRECT MIXTURE OF UNDERBODY COATING AND OVER-APPLICATION CAN RESULT IN RIGID, ICICLE-LIKE AREAS HANGING FROM VEHICLE'S UNDERCARRIAGE.
Consequence:
IF THIS CONDITION EXISTS, THE UNDERBODY COATING MAY PENETRATE THE FUELS LINES AND CAUSE FUEL LEAKAGE, INCREASING THE RISK OF A FIRE.
Remedy:
DEALERS WILL INSPECT THE VEHICLE UNDERCARRIAGE, AND IF EXCESSIVE UNDERBODY COATING IS FOUND IN THE FUEL LINE AREA, IT WILL BE REMOVED. IF THE INSPECTION REVEALS THAT THE FUEL LINES ARE DAMAGED, THEY WILL BE REPLACED. THE SAFETY RECALL BEGAN ON APRIL 25, 2012. OWNERS MAY CONTACT VOLVO CUSTOMER CARE CENTER AT 1-800-458-1552.
Notes:
VOLVO SAFETY RECALL NO. R251. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO
