1 - 2 of 2 Posts
Hey all - I've got a 2017 V90 CC and usually use the intermittent speed on the rear wiper if I need it. Recently, I clicked down to activate what I thought was the constant speed for the wiper. It ended up being constant for about 4 times before it stopped for about 10 seconds and then repeated 4 times or so. Is this typical? I thought it might be consistent but perhaps I'm wrong?
I think it's best to ask your dealer's Service Dept when wondering about things like this.
The 2017 V90CC Owners Manual is available on line at https://volvornt.harte-hanks.com/manuals/2017/V90CC_OwnersManual_MY17_en-US_TP22415.pdf.
On p 159, it says "The rear wiper is equipped with a cut-off
function, which means that it will not operate
if its electric motor overheats. The wiper will
function again after a cool-down period
(30 seconds or longer, depending on the heat
of the motor and ambient temperature conditions)."
I wonder if this is what you are experiencing. Again, I'd think that your dealer's Service Dept could tell you (a) whether you are and (b) whether you should.
I personally have not used the constant setting so cannot speak to my experience.
1 - 2 of 2 Posts
