Need a rear universal joint repair kit for a 1959 544 1.6l would anyone have a reference number?
Cheers Colin
Cheers Colin
The u-joint is Volvo Part Number 672037 (u-joint with four circlips and one grease fitting), the flange bolt set is 273202 and the two-hole locking tab is 15260.
These parts fit the "small" driveshaft and the specs for the new u-joint show "61mm".
George Dill
http://hiperformanceautoservice.com/product_info.php?cPath=50_68_124&products_id=104
http://hiperformanceautoservice.com/index.php?cPath=50_68_124
http://www.skandix.de/en/spare-part...oint-propeller-shaft-universal-joint/1000112/
They are a very common U-joint among smaller cars. If you carry your old one (or the pieces) to a parts store they can probably match it.
The Chinese say...
Specifications
Universal Joint
OEM NO:672 037
Length 61.5 mm
Outer :23.8 mm
CAR MAKE:VOLVO /ISUZU
Length : 81.8 mm
Outer Diameter : 27 mm
George Dill
