I happen to have a broken rear tail light (the lower chubby one) and am unsure to find how it is fastened in?
Is it easily replaced or am I going to have to get the dealer to do it?
Any input would be appreciated, thanks a lot!!
Re: Rear Tail Light Replacement?? (aut0psy)
Its in the manual, you have to take it off to change one of its bulbs as they are changed from outside the car, you'll see. It's a 5 minute job.
Re: Rear Tail Light Replacement?? (XC90 Black Saphire)
The assembly seems like it bolts in, I couldnt find it in the manual?
I assume I have to take the inside panel off and the nuts attaching it will be in there?
Yeah you have to take the inside panel of and there are these two "bolt things". They are more like long rods. You take them out and then pull the light out, it helps to wiggle it a little.
