what exhaust is that??My friend and I did rear sways on his and my ride in the span of 3 hours. What you need to do is:
- jack up the rear of the car; remove both wheels
- unbolt the rear driver's side shock from the BOTTOM ONLY (no need to loosen up the top)
- While someone pushes the loosened shock towards the front of the car, you can wiggle the bar out.
- The install is exactly the same but in reverse.
Good luck!
It's a TME exhaust on my buddy's R. The tips are a bit dirty but it sounds really really goodwhat exhaust is that??
Tips are clean nowIt's a TME exhaust on my buddy's R. The tips are a bit dirty but it sounds really really good
You need an associate to help clean from time to time my friendTips are clean now![]()
the hint is the R with the VST... lolMy associate's identity will remain hidden and will not be named at this time!
