1 - 16 of 16 Posts
Well, I'm trying to put together a laundry-list of the things to order to have my shocks/struts replaced. Think I know everything I'd want for the front, but, when it comes to the rear, are there any wear parts? Only thing I'm finding on IPD is the "Upper Strut Mount." Is this the spring seat for the rear shocks? Is that something different? Are there any other wear parts for the rear suspension? (Rear end links, maybe?)<p>Thanks! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Re: Rear shocks: any wear parts back there? (StarmanDXE)
Rear shock mounts and they can break<br>(Cheap)
Re: Rear shocks: any wear parts back there? (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>shagginwagon</b> »</i></TD></TR><TR><TD CLASS="quote">definitely do rear endlinks at the least.</TD></TR></TABLE><p>Kk.<p><br><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">Rear shock mounts and they can break (Cheap)</TD></TR></TABLE><p>I assume that's the same as the "Upper Strut Mount"? Maybe that's what's broken and causing the horrible noise from the rear right tire whenever I go over a bump... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
No it's not<br>
It's not what? The upper strut mount? Or the cause of the noise?
Just make sure you tighten the bolts when the car is on it's feet.<p>Often unwanted sounds and also behavior can be noticed when the bolts are tightened while the suspension arms are hanging. This way wrong tension is set on the bushings.
Re: (volvo0toS60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>volvo0toS60</b> »</i></TD></TR><TR><TD CLASS="quote">is it better to use some xc90 parts for the suspension? if so which ones?</TD></TR></TABLE><p>I know for sure people are using the spring seats in the front from the XC90. Not sure if any other parts are different (better) <i>and</i> compatible.<p><br>Alright, here's a diagram of the rear suspension. I guess the part IPD has is #9.<p>JLR: were you referring to part #6? Or some other part maybe?<p>Thanks <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"><p><IMG SRC="http://lh3.ggpht.com/_eE0yNOema1A/Sl34mH7pe5I/AAAAAAAAA_M/zYwnwq-kcPI/s800/untitled.JPG" BORDER="0">
Re: (StarmanDXE)
6
Thank you, sir.<p>So, that's a "replace if broken" part? Are there any wear parts? Like maybe #5, #9, or #10?
Re: (StarmanDXE)
Probably.<br>When I rebuild a suspension I use ALL new parts.<br>You have a 9 year old car with over 100K miles. Nice old rusted bolts, plates, washers, gaskets, etc.<br><B>Use all new pieces</B>
Discussion Starter · #13 ·
Re: (JRL)
Thanks for the words of wisdom! <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Discussion Starter · #15 ·
Re: (volvo0toS60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>volvo0toS60</b> »</i></TD></TR><TR><TD CLASS="quote">say i wanted to check up on the rear suspension and see if anything is cracked or broken....what should i do to go about doing that?</TD></TR></TABLE><p>+1<p>I think I remember reading that you replace the shocks in an 850 through the trunk(?) If it's the same in the S60, I would imagine that you'd check the top mounts there and then check endlinks and swaybar bushings underneath...
Discussion Starter · #16 ·
Bring this back from the dead...<p>Are there control arm bushings in the rear which require regular replacing like there are for the front?
1 - 16 of 16 Posts
