Moderator
I'm just replacing the shock plate, the washer and mount are just metal parts.
+1 just do the support plate which is the rubber upper shock mount. There are also rubber upper spring seats you could consider replacing but at I'm at 125k and have them out right now and they look perfect.
Thanks for the reply’s. I agree. The other parts are metal and should be fine. A visual confirmed this. Placing order now for the support plates. Looks like I’ll finish this up by Saturday to get the full effect of the rear TME’s and new 4C’s. So far the front are spot on.
