Hi,
I’m considering replacing the rear lower engine mount on my 02 V70XC. I’ve done (this pig) of a job on my fwd S60 and was wondering whether it’s much more difficult with the AWD in the way. Has anyone done this job? If so any comments?
Not too bad a job
Same as a fwd.
Use R motor mounts.
Wobble extension(s) are very helpful
I have done the job on my AWD D5. It is about the same as as FWD car.
It is a little easer if you drop the back of the subframe. Unbolting the rack so it stays in place, as you lower the subframe down from it.
The only problem I have is I have got to do it again as the good used mount I had has now split it vacuum diaphragm.
On the Diesel D5 the mounts have a vacuum pipe going to them , to adjust the hardness of the mounts depending on engine speed.
Unfortunately on the new ones you also have to change the aluminium bracket as Volvo changed the mount design.
Thanks guys. Sounds very doable.
