1 - 10 of 10 Posts
I have a 2007 XC70 with factory Foglights in front, and after a little reading, aparently I have ONE in the rear. The button makes the drive side rear light REALLY BRIGHT. Has anyone rewired it so that BOTH lights have that capability?<p>Thanks.<br>
Re: Rear Foglight Mod ?? (Mika)
I know its supposed to be only one... what I want to know is if anyone ever tried to make it BOTH.<br>
Re: Rear Foglight Mod ?? (idlemind)
So your plan would be to have it so in dense fog people could not see when you are applying your brakes?
On my 960, the socket is there but filled with plastic, and the wires are there, hooked up and everything. It would just be a matter of dremeling out the plastic and putting a bulb in. Not sure if they still do that on the newer cars, but I might check on my V70 if I ever pull the taillights out.<p>I've kicked around the idea of jumpering that socket to the brake lights, so you light up the sky like a close encounter when you put your brakes on. The only reason I haven't done any of that is the prospect of cleaning plastic bits out of the inside of the taillight sounds like no fun at all.
Re: Rear Foglight Mod ?? (wingdo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>wingdo</b> »</i></TD></TR><TR><TD CLASS="quote">So your plan would be to have it so in dense fog people could not see when you are applying your brakes?</TD></TR></TABLE><p>...must you? Really? The third brake light is plenty visible, and since better than 80% of cars on the road have no rear fog lights at all compounded with the fact that I'm in NYC and dense fogbanks are few and far between, I think I'll be fine. My plan is to have them both be the same and use them at my own discretion.<p>I'm very familiar with the 40+ car pile-ups elsewhere in the US and I'm pretty sure rear fog lights would not have made much difference.
Re: (LloydDobler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>LloydDobler</b> »</i></TD></TR><TR><TD CLASS="quote">On my 960, the socket is there but filled with plastic, and the wires are there, hooked up and everything. It would just be a matter of dremeling out the plastic and putting a bulb in. Not sure if they still do that on the newer cars, but I might check on my V70 if I ever pull the taillights out.<p>I've kicked around the idea of jumpering that socket to the brake lights, so you light up the sky like a close encounter when you put your brakes on. The only reason I haven't done any of that is the prospect of cleaning plastic bits out of the inside of the taillight sounds like no fun at all.</TD></TR></TABLE><p>Thats kinda what I was thinking... and the same downside came to mind... I suppose I could buy a set from the junk yard and see what happens... but it was more of an inquiry than a TO DO....<p>thanks.<p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>idlemind</b> »</i></TD></TR><TR><TD CLASS="quote">I know its supposed to be only one... what I want to know is if anyone ever tried to make it BOTH.<br></TD></TR></TABLE><br>Yes, it's been done<U> <B>but DON'T you do it</B> </U>or you can have some really pissed off driver behind you!<br>I almost ran a Benz off the raod a couple of years ago, You have no idea how bright they are and how blinding and annoying it is to be behind someone who has it on in clear weather
Re: Rear Foglight Mod ?? (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Yes, it's been done<U> <B>but DON'T you do it</B> </U>or you can have some really pissed off driver behind you!<br>I almost ran a Benz off the raod a couple of years ago, You have no idea how bright they are and how blinding and annoying it is to be behind someone who has it on in clear weather</TD></TR></TABLE><p>I figured as much, thanks.. I've seen how bright it is.. It would have basically been for backing the trailer into the driveway and stuff like that. But I understand.
1 - 10 of 10 Posts
