They say they're toe arms, not camber arms (I've never heard of an S40 needing extra toe adjustment). From looking at the pic and having no scale reference, I'd guess they do not fit. The straight, round bar is too different from my flat, cast pieces.
Try asking them, though.
The SPC 67420 fits, it's what I have.
Re: (mattdoc)
I also have this the guy told me toe means camber where he is from i didnt think it was the same !?!? but he said it the arms fit this should but idk
I also just got the spc kit (100$ new)
I already asked if he had more for u guys but he only had one set so sorry
Re: (mattdoc)
In our car, rear camber does affect rear toe because of the geometry of the lower arms. They're asymmetrical, on purpose for handling. As the camber increases, so does toe-in. In fact, you can't adjust the two parameters independently in ours, stock. Only the toe-in can be tweaked, and camber changes only slightly. The aftermarket arm corrects this.
Tom.
Re: (tmtalpey)
Good One Tom , I'd say the Might be able to be Uses as Sway bar End Links - on some other models , Even then they are Solid Link by the Looks
and Will Transmit a lot of - Noise and Vibration .
Dan
Re: (EngTech)
What i cannot figure out is after this lowering i have the rear camber actually looks like it no longer an issue ill take some pics to show you what i mean ....
(where is the best place to upload photos from ?)
