Re: Rear deck speakers and amp..Chinaonnitrous1 HELP (CM2RAS)
If you want to properly access them, you need to remove the rear shelf.
Quote, originally posted by AthruC » |
I believe it's the spot that the actual speakers get soldered to the wire leads. Interesting idea - I was a bit worried about them grounding out on the rear shelf, but I guess not. You CAN see the posts from the trunk - I guess there's enough room to use an alligator clip ![]() |
Quote, originally posted by chinaonnitrous1 » |
...This is GHETTO... |
Quote, originally posted by 850arrrsaylikepirate » |
You got that right. |
YUP! I need whistle tips.... |
And plastic spinners. |
Bolt, hell lets use some double stick tape, no wait, duck tape. |
