This is just a thought but has anyone see the brake light iluminate the cargo area in the V40 when it is dark and you press the brake?<P>this is extremly dangerous in the dark when backing up and then you press the break and you can no longer look out the rear window beacuse it is so bright!<P>Not sure if anyone noticed this or if it is just my car! <P>I had it fixed by placing black foam around the light where it meets the glass, looks factory and i no longer have to back up without using the brake!<P>mitch<P>
