Got a code BCM-C003907 Right Rear Tone Wheel Mechanical Failure (along with some ABS/braking system warnings and lights on the dash).....VIDA shows p/n 30735955 for the front rings, but doesn't even show the rear rings on the parts diagram. Does anybody know if it's the same part for front and rear? ('05 V8 AWD)
Ring is inside the wheel hub for the rear per VIDA: Design and Function_593: Brake control system.
Thanks. Yeah, that's completely different....I can't find any indication that the ring can be found as a separate component (or that it's removable from the hub at all). Will have to put it up this weekend and take a look.
