“If you disconnect the DEM the warning will always be there. You can diagnose the wheel sensors with a pro tool or VIDA - basically, drive straight and slow and read each wheel speed.
If not available, then closely inspect each rear wheel. The sensor is a little nub at 12 o'clock above each axle, with a single wire leading to it. Inside the hub, there's a star-shaped ring, the points whizz past the sensor and send pulses. Sometimes, those teeth fall off, or the whole ring gets mashed.
Maybe it's just a broken wire or pulled connector.”
Thanks tm. I put the V50 on ramps last night and fumbled around each wheel to see if anything was obviously loose or broken around the wheel sensor(s). Nothing obvious. Then again - these sensors are in pretty awkward locations, so I probably missed something.
As I mentioned in my response to MyName - I’ll call the Volvo Service Advisor and ask some pointed questions about their diagnosis of a bad DEM. I suppose I should have started a new thread topic about my problem...but it’s so much more fun to get responses from “The Collective” on this thread.
