Finally managed to pull out my plugs carefully without breaking all the coil connector clips. Thanks to the help from this community.
These spark plugs done some 30k miles and I was wondering if anyone can comment on their condition. I noticed that on plugs 3, 4 and 5, there were some light red deposits on the ceremic insulator. Is that a good sign?
Anyway, I have replaced all plugs and coils and power is back! Many thanks.
Red dots and/or red blotching is typically caused by octain boosters and/or fuel additives. Long as its not covering the point its not effecting your performance.
"reading" plugs is pretty much obsolete with modern EFI and O2 sensors. Did you check the gap in the old plugs? I had slight misfires under heavy throttle on my 25k spark plugs, the gap had opened to .034" from the .028" I install them at, and of course with new plugs the misfire went away. The lesson I take away from this is to change plugs at the first sign of misfire.
The red blotches must be from the Redline fuel system cleaner I used once many months back. It seems like it did not clean through injectors 1 and 2 - can't really conclude.
The gaps are still around .025", gapped from factory. My idle was rough and dropped momentarily when placed into D or R. I changed the plugs and coils and now have a smooth idle and revs hard to redline under load. I also noticed that a ECM reset by taking the battery terminal off for some time helped. Thanks.
