1 - 6 of 6 Posts
If it's just the speaker grilles and not the whole door panel, you could take the grille off from the back and re-glue it with shoe goo. It is a flexible epoxy, and would absorb the vibrations.
They should be glued on the inside of the door panel. You have to take the whole panel off.
I found that inside door rattles come from loosen window support fixation with metal on door. need to drill old rivets and place bolts with non return nut. I tried first to place new rivets but after two years same vibrations come back. than I drill out rivets.one by one please...drill a mm bigger holes and placed bolts. never again vibrations. as window mechanism is quite strong all .frame of rising lowering door window is shaking in strong forces when we push window button rivets slightly by time dancing and have gap. than window mechanism vibrating. see photos.
Club Volvo Italia
Raduno a Sicilia
Pasqua 2016
1 - 6 of 6 Posts
