1 - 9 of 9 Posts
any thoughts out there, rattle like something is loose when driving at very slow speeds, straight and slow turns. I am told something rubbing with axle and bearings. two shops have looked and ok'd CV, spring seats, bearings etc.. driving me nuts
Re: (heus33)
it is not, smooth road like leaving a parking lot and or starting from a dead stop.
I may be experiencing the same problem u are. Is it like when u turn the wheel and press the gas it rattles near the left side of the steering wheel near the air vent? and sometimes it rattles and sometimes it doesnt. I usually hit the top of my dash kind of hard and it goes away...idk what it could be, but i would really like to know...
Re: (heus33)
I rattle over small bumps, what's your thought? Thanks
Re: (mjaffe)
I had that one, could be the strut mounts, I am convinced mine has something to do with the brakes, maybe brake clips that hold the pad..
Re: (row)
Don't neglect the registration holder (or whatever it's called) at the windshield. Although I would imagine you'd be able to tell if the noise was coming from there, it's still worthwhile to put some felt tape between it and the glass and see if your noise goes away.<p>Duh, driver's <i>wheel</i>, not driving wheel (which would have been odd anyway, as most people call it a steering wheel), so disregard my post and good luck figuring out your noises <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"><br><BR><BR>
<i>Modified by JoeLvo at 5:02 PM 5-1-2009</i>
Re: rattling coming from front drivers wheel (row)
Problem found! the Brake Vacuum Pump bracket was loose! <p>..... another volvo noise attacked!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>row</b> »</i></TD></TR><TR><TD CLASS="quote">Problem found! the Brake Vacuum Pump bracket was loose! <p>..... another volvo noise attacked!!!</TD></TR></TABLE><p>congrats,<p>you should maybe consider contributing to Phuz's rattle list/fix <A HREF="http://forums.swedespeed.com/zerothread?id=106544" TARGET="_blank">thread</A>?<br>
1 - 9 of 9 Posts
