1 - 13 of 13 Posts
Hey guys,
I've been driving around with the windows down alot recently, and i sometimes hear a chain like rattle coming from the front left corner. Sounds almost like a loose bolt somewhere
Hey guys,
Could be from the A pillar panel,from a clips!!
i'll check, but i think it's much lower than the a pillar. and definitely outside the car
Make sure that the axle bolt is not loose.
so, took out the center cap on my fron t left wheel. axle bolt was not attached at all. is there a torque specification for this bolt?
There may be noise from the drive shafts, the splines!
It is very common on these cars.That noise arising from the towing position and when you pull away!
From VIDA:
Bolt drive shaft - wheel hub, front: Stage 1: 35 Nm, Stage 2: 90°
or
Bolt drive shaft - wheel hub, version with rubber cone: 50 Nm
From VIDA:
or
so, i first torque it to 35 nm and then go another 90 degrees?
Maybe a little loctite for a little insurance.
awesome, thanks guys!
Axle bolt sounds like a chain rattling. Just happened to me a few days ago.
1 - 13 of 13 Posts
