1 - 10 of 10 Posts
I am selling off all of my Volvo stuff to finance a truck. Please feel free to ask me any questions you may have. Most everything I have works for 850's or x70's. Prices don't include shipping.
IPD Heavy Duty front upper spring seats with 8K on them. They look fantastic with no cracks or play in them. SOLD
Sachs upper strut mount bearing with 8K on them. Made in Germany. Rotate smoothly and look great. SOLD
Front strut dust boot covers. Brand new and never installed. $6 each.
Front strut bump stops. Brand new and never installed. $15 each.
Custom turbo-back exhaust from 1997 850 R sedan. Should work on S70's, not sure if the wagons are longer or not. Turbo to Cat is 3 inch pipe, with O2 sensor in front of and behind Cat. The Cat rattles around a bit. The muffler is a 2.5 inch Magnaflow straight-thru with polished tip. The tip has a dent on the top of it, but it's not too noticeable when installed. Includes clamps for the flanges. I'd prefer to sell locally, since shipping would be a royal pain. More pictures available on request. $350.
Various foglight related relays and dash switches for adding foglights to your car. $5 per switch, $3 per J relay, $12 per main light control relay or 213 relay.
Defrost, TRACS, and Sunroof switches from '97 850R. $4 each
Various climate control knobs and blanking plates from 850's. $1 each
2 non-turbo intake manifolds. I accumulated these while on my search for the correct number of vacuum ports. One is from a '94 850 and has a vacuum variable adjustment thing on it. The middle one in the pic is SOLD, and the top one is from I believe a '96 850 and currently has a throttle body mounted on it. I can sell the throttle body separately if you like or pair it up with a different manifold. Great for doing the Snabb N/A throttle body swap on your turbo car! Your choice manifold is $50.
Key fob for 850 models. SOLD!!!
Key fob from an '01 XC70, works for early P2 cars. Part # 9459368 Decent condition and no cracks. $15
OEM ECU from '98 V70 AWD automatic. Works perfectly. $50
Red injectors from '98 V70 AWD. In good condition and worked perfectly when removed. $80
Prosport Performance water temp adapter pipe. For threading in a water temp sensor. 38mm. Brand new in opened box, perfect condition. $20
Beige passenger side front underdash cover. This is from a 2000 XC70 and has the desirable map pocket with anti-slip pad. It's in very good condition with just one very small nick. Will clean up nicely. $40
OEM air intake hose with PTC sensor. In good condition. $25
S70/V70 chrome grill without Volvo slash. All mounting tabs present and no cracks. Has a few chips, but still very serviceable. $55
Volvo OEM rear door 5 1/4 inch speaker from an 850. Should work with x70 models too. Not blown, no tears and works fine. The shield on the back is cracked, but it does not effect the speakers operation. $5
OEM Bosch ignition coil from '98 V70 AWD with ignition cable. Works great. $25
OEM Spark plug harness from a '98 V70 AWD. Work great with no cracks or nicked wires. $30
IPD strut brace for 850 and x70 cars. In very good condition. Made a noticeable difference in my opinion. $125
OEM airbox from '98 V70 with SAS hookup. Good condition with no holes or cracks. $25
Factory 17" donut spare tire from '98 V70. Holds air and is in good condition. $40
OEM catalytic converter from '98 V70 AWD. Works perfectly, no error codes, rattles, damage, or rust. Was removed to install an aftermarket exhaust. $125
<a href="http://s347.photobucket.com/albums/p475/beewerks/2011-08-04/?action=view¤t=IMG_9271.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/2011-08-04/IMG_9271.jpg" border="0" alt="Photobucket"></a><br>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view¤t=IMG_8699.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_8699.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/2011-02-26/?action=view¤t=IMG_8881.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/2011-02-26/IMG_8881.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/2011-02-26/?action=view¤t=IMG_8883.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/2011-02-26/IMG_8883.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/2011-02-26/?action=view¤t=IMG_8884.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/2011-02-26/IMG_8884.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/2011-08-14/?action=view¤t=IMG_9282.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/2011-08-14/IMG_9282.jpg" border="0" alt="Photobucket"></a>
</a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/2011-11-17/?action=view¤t=IMG_9457.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/2011-11-17/IMG_9457.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view¤t=IMG_0082.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0082.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view¤t=IMG_0083.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0083.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view¤t=IMG_0084.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0084.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view¤t=IMG_0085.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0085.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view¤t=IMG_0086.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0086.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view¤t=IMG_0087.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0087.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view¤t=IMG_0088.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0088.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view¤t=IMG_0092.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0092.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view¤t=IMG_0089.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0089.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view¤t=IMG_0094.jpg" target="_blank" rel="nofollow"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0094.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view&current=IMG_0469.jpg" target="_blank"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0469.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view&current=IMG_0468.jpg" target="_blank"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0468.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view&current=IMG_0463.jpg" target="_blank"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0463.jpg" border="0" alt="Photobucket"></a>
<a href="http://s347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/?action=view&current=IMG_0462.jpg" target="_blank"><img src="http://i347.photobucket.com/albums/p475/beewerks/Stuff%20to%20Sell/IMG_0462.jpg" border="0" alt="Photobucket"></a>
interested in the key fob. are the buttons worn or is that the photo? is it relatively simple to reprogram?
The fob in that picture has actually been sold, but I have another one with a good case. The unlock button writing is good, but the lock writing is worn off. The rubber over the two buttons is perfect though. Let me know if you are interested!
Zimmerman rotors are sold!
OEM A-Arm sold!
Lowered some prices and added more parts.
PM replied to. Oil Filters, 850 Fob, and MAF sensor SOLD!
Bump. :)
1 - 10 of 10 Posts
