1 - 2 of 2 Posts
Looking for something better than the stock hu-613 40 watt cheepo radio in my 02 v70xc. I found out that they offered a 50 watt and a 100 watt. Anybody out in the volvo community have one better than mine for sale!!.
Only upgrade is an 803 Dolby (great radio)
You will need the separate underseat amp (either 200w or 300w) and harness that is needed.
Your radio has an internal amp, the 803 requires the external amp
Also needed to get the best effect is a center spraker and new grill.
(P2s are all pre wired for the center speaker)
To get the best out of that then you will need to upgrade your speakers
www.erievovo.com may have one in stock (used)
Also your 613 has a hidden eq menu that when adjusted properly GREATLY enhances your sound
That along with a factory subwoofer make for a decent system.
Unfortunately these subs have become almost unobtanium especially the sub harness, neither has been made for years now.
Hidden Equalizer
With the radio switched off, press and hold down [SOURCE], press [Volume] to power
on the radio, and continue to hold down [SOURCE] for at least 5 seconds.
�� Press [SOURCE] to select a function
�� Turn [SOURCE] to adjust value
Function Description
FRONT Low1 3 Adjusts the very low frequencies in the front. Valid values
are from 0 to 6. Factory default for S60 is 4.
FRONT Low2 3 Adjusts the low frequencies in the front. Valid values are
FRONT Mid 3 Adjusts the mid frequencies in the front. Valid values are
from 0 to 6. Factory default for S60 is 6.
FRONT High 3 Adjusts the high frequencies in the front. Valid values are
REAR Low 3 Adjusts the low frequencies in the back. Valid values are
REAR Mid 3 Adjusts the mid frequencies in the back. Valid values are
from 0 to 6. Factory default for S60 is 0.
REAR High 3 Adjusts the high frequencies in the back. Valid values are
1 - 2 of 2 Posts
