1 - 16 of 16 Posts
Discussion Starter #1
When I change stations in my car on the FM tuner, often times the sound comes in for a blip of a second then it says "searching" on the display. If i turn the radio off and on again it works fine.<p>Known issue?
Re: Radio Stations goto 'Searching' frequently (AbsolutZer0)
Yes. It's the RDS data being saved with the station.<p>Re save the station before the RDS info is received and you won't have the problem anymore.
Discussion Starter #3
that was quick. Thanks!
Re: Radio Stations goto 'Searching' frequently (Arbelac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Arbelac</b> »</i></TD></TR><TR><TD CLASS="quote">Yes. It's the RDS data being saved with the station.<p>Re <B>save the station before the RDS info is received </B>and you won't have the problem anymore.</TD></TR></TABLE><p>What do you mean?<p>Save the station as in "make it a preset?"<p>
Re: Radio Stations goto 'Searching' frequently (cucharon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>cucharon</b> »</i></TD></TR><TR><TD CLASS="quote"><p>What do you mean?<p>Save the station as in "make it a preset?"<p></TD></TR></TABLE><p>Yes. Save the preset by manually tuning and saving immediately, BEFORE the RDS data is present. Then when you switch stations, it doesn't wait for the RDS data to be the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Arbelac</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Yes. Save the preset by manually tuning and saving immediately, BEFORE the RDS data is present. Then when you switch stations, it doesn't wait for the RDS data to be the same.</TD></TR></TABLE><p>All of my stations are "saved as presets," yet when I change from preset #1, to preset #2 I still get the 2 second music preview followed by "searching."<p>
You've got RDS data saved with the preset. Go someplace where you have no signal or very weak signal and reprogram them (e.g. bottom of an underground parking garage...)<p>That should solve it (did for me).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Arbelac</b> »</i></TD></TR><TR><TD CLASS="quote">You've got RDS data saved with the preset. Go someplace where you have no signal or very weak signal and reprogram them (e.g. bottom of an underground parking garage...)<p>That should solve it (did for me).</TD></TR></TABLE><p>ROGER, ROGER!!<p>Thanks! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
There's also a feature that tries additional fine tuning. One of my presets was always "Searching" after a few seconds, then coming back. I disabled the feature and it solved the problem.
Re: (asdf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>asdf</b> »</i></TD></TR><TR><TD CLASS="quote">There's also a feature that tries additional fine tuning. One of my presets was always "Searching" after a few seconds, then coming back. I disabled the feature and it solved the problem.</TD></TR></TABLE><p>In the advanced radio menu, which setting is it to disable? This could also be my issue as well.<p>Thanks! <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Arbelac</b> »</i></TD></TR><TR><TD CLASS="quote">You've got RDS data saved with the preset. Go someplace where you have no signal or very weak signal and reprogram them (e.g. bottom of an underground parking garage...)<p>That should solve it (did for me).</TD></TR></TABLE><br>It's not a bug, it's a feature! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
Re: (cucharon)
<A HREF="http://new.volvocars.com/ownersdocs/2005/2005_V70/05v70_10b.htm#pg177" TARGET="_blank">http://new.volvocars.com/owner...pg177</A> <p>Scroll down to automatic frequency update...I *think* that's what I disabled, although it doesn't really do what I described.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote »</i></TD></TR><TR><TD CLASS="quote">PI (Program Information) Seek:<br>When an FM station has been stored as a preset, <b>the radio also stores RBDS program information if it is available</b>. When the preset is selected at a later time, the radio tries to access updated program information. In weak signal areas, there may be a delay before the station becomes audible. During this delay, "PI seek" will be displayed and there will be no sound.<br>PI seek can be interrupted by pressing EXIT. </TD></TR></TABLE><p>Bolded is my emphasis. There is a TNN advice document on this as well.
Re: (Arbelac)
When it goes to "searching" you can just hit "EXIT" rather than powering off and on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Arbelac</b> »</i></TD></TR><TR><TD CLASS="quote">You've got RDS data saved with the preset. Go someplace where you have no signal or very weak signal and reprogram them (e.g. bottom of an underground parking garage...)<p>That should solve it (did for me).</TD></TR></TABLE><p>I never knew this one, thanks...<br>-Aaron<br>
1 - 16 of 16 Posts
