I have a 2005 Volvo S60r
Any links to instructions on removing the radio and the trim around it?
Thanks guys
here is how to remove the trim.
Remove the bezel around the shifter. There will be two torx screws under the climate unit. Remove those two screws, then pull from the bottom and it should come out. And for the trim, there will be a few screws and a few tabs. Remove the screws and push in the tabs with a flat head screw driver and the trim will come out.
