How do I remove the CD changer in the glove box without cutting it's cable. Need the glove box space. <br>Do not know how to remove radio without causing damage.<br>Assume plastic panels will pop off if pried the correct way.<br>
take car key <br>push in little tabs on the side of the radio<br>they pop out <br>pull and remove radio
Re: (Chilled Man)
after you do what chilled man said then you just disconnect the CD changer cable. After that you should be able to remove it from your glove box.
