1 - 6 of 6 Posts
I am trying to get to the headunit of the radio, specifically where the antenna wire connects, I am completely lost as to how to get access to that and where it is. If anyone has info as to how to do that it will be greatly appreciated.<p>Thanks!
Re: Radio Help! (cabbazio)
the headunit is located in the right side of the trunk... at least that's the case with V50s... but should be the same in S40s, too... <p>you'll have to dismental some of the trunk lining, then you'll have access to the multimedia module -left side / radio head unit - right side.<br>so don't get mistaken by other cars, it is not behind the center console <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <p>don't know about the wiring, though.
I took the trunk apart and all I saw was something that resembled an amplifier on the left side and nothing on the right side <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0">
what about the white box located under the left foot rest (dead pedal area)? I thought I heard that was for antenna wires as well. No?
Re: (Veefifty T5AWD)
<IMG SRC="http://i43.tinypic.com/kd2ur7.jpg" BORDER="0"><p><IMG SRC="http://i43.tinypic.com/2qxx66b.jpg" BORDER="0">
Re: (slrising)
cabbazio, let me know if these work or if you need a bigger/better resolution I can email them to you. Not sure which module the antenna connects to though I would image the AFM though?
1 - 6 of 6 Posts
