1 - 20 of 20 Posts
I have a 1995 850 turbo with a audio system model SC-811 and was wondering if anyone knows the code? I need to disconnect my battery soon!<p>Thanks
Re: Radio code anybody? Need to disconnect my battery soon! (guidowitz)
Here we go again.<br>How the HELL are <B>WE</B> supposed to know <B>YOUR</B> code?<br>That's why it's called <B>A CODE!</B> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> <p>Anyway, if you know how to remove the radio, (and your dealer will not give you the code) write down<U> <B>ALL the numbers</B> </U>on the top of the radio and email them to me, I can get you your code (sigh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>guidowitz</b> »</i></TD></TR><TR><TD CLASS="quote">I have a 1995 850 turbo with a audio system model SC-811 and was wondering if anyone knows the code? I need to disconnect my battery soon!<p>Thanks</TD></TR></TABLE><p>You might not get as lucky as I did, but the first time I disconnected my battery and realized I didn't have the code, I took the radio out and, in the process, noticed that someone wrote it down in pen on the serial number sticker. It's worth looking, at least. Should be four numbers.
Re: Radio code anybody? Need to disconnect my battery soon! ([email protected])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>[email protected]</b> »</i></TD></TR><TR><TD CLASS="quote"><p>You might not get as lucky as I did, but the first time I disconnected my battery and realized I didn't have the code, I took the radio out and, in the process, noticed that someone wrote it down in pen on the serial number sticker. It's worth looking, at least. Should be four numbers.</TD></TR></TABLE><p>OK thanks.
Re: Radio code anybody? Need to disconnect my battery soon! (Chow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Chow</b> »</i></TD></TR><TR><TD CLASS="quote">what is the full VIN number??</TD></TR></TABLE><p>VIN: YV1LS5714S1261450
same with me..was written on top of radio. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> <br> I believe you can get it from any volvo dealer.. have heard some wanna charge for it but some give it up fer free.<br>Best of luck!
Re: Radio code anybody? Need to disconnect my battery soon! (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Anyway, if you know how to remove the radio</TD></TR></TABLE><p>not really JRL..can you enlighten us?<p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>guidowitz</b> »</i></TD></TR><TR><TD CLASS="quote"><p>not really JRL..can you enlighten us?<p></TD></TR></TABLE><br>Gees,<p>I thought I already told you this!<br>There are two little vertical slot tabs on each side of the radio about 3/4" tall.<br>Use a pen tip or something with a point to push them slightly in. <br>Then they will pop out and you will have two little "handles".<br>Just pull the radio out slowly.<p>Reverse the above when putting it back
Thanks JRL, but no you never mentioned this procedure to me before.<p>I found the answer today also on bay 13:<p>1.) Find the radio code first – then remove the radio by pressing in the little latches on the side so they pop out and you can pull the unit out. Undo the connectors and pull out the antenna.<p>2.) Start disassembly with the knobs – they pull straight off. I had to pry a little with cardboard under the little screwdriver so I didn’t mark the faceplate. Remove a screw on each side in the black plastic track closest to the faceplate. On the top and bottom of the radio you will need to pry the faceplate off the metal frame of the radio. If you go gently, you’ll be able to see where it’s clipped on. This is a very complicated plastic part so you really don’t want to hurry and crack it.<br>
BTW: Find out where your Volvo has been serviced. In my case, I'm the 3rd owner. I just called the shop where the car has spent its past life and they happily gave me the code...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>guidowitz</b> »</i></TD></TR><TR><TD CLASS="quote"><p><br>2.) Start disassembly with the knobs – they pull straight off. I had to pry a little with cardboard under the little screwdriver so I didn’t mark the faceplate. Remove a screw on each side in the black plastic track closest to the faceplate. <B>On the top and bottom of the radio you will need to pry the faceplate off the metal frame of the radio. If you go gently, you’ll be able to see where it’s clipped on. This is a very complicated plastic part so you really don’t want to hurry and crack it.</B><br></TD></TR></TABLE><br>What's all this about?<br>Code is not anywhere on the radio<br>Just pull the radio, write down ALL the numbers on top.<br>Give them to your Volvo dealer.<br><B>If he can't help you, I can</B>
I am going to have to reset my friends s70 tomarrow it needs the four digit code and is now locked out because she tried guessing it three times. Hoping its written on the top like your scenarios ill let you know what happens... <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Just to reiterate, you probably don't want to start disassembling your radio for no reason. That could prove to be a headache.
Re: (Big Will)
mine is written on top of the radio (6655 ftw). i have to take mine out regularly and spray the volume knob with electronics cleaner to get rid of the scratchiness and static when changing the volume.
Re: (pilotguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>pilotguy</b> »</i></TD></TR><TR><TD CLASS="quote">mine is written on top of the radio (6655 ftw). i have to take mine out regularly and spray the volume knob with electronics cleaner to get rid of the scratchiness and static when changing the volume.</TD></TR></TABLE><p>Good for you, most are not
It's simple. All you have to do is start at 0000 and work your way up. When it locks you out wait a while and resume. You'll find it within a few months.<p>Or just do what JRL has said.<p>
Re: (firehawk618)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>firehawk618</b> »</i></TD></TR><TR><TD CLASS="quote">It's simple. All you have to do is start at 0000 and work your way up. When it locks you out wait a while and resume. You'll find it within a few months.<p>Or just do what JRL has said.<p></TD></TR></TABLE><p>LOL thats just wrong
I think if you pop out the radio just look on the top inside the code should be stuck on by sticker
Re: Radio code anybody? Need to disconnect my battery soon! (mark_850t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>mark_850t</b> »</i></TD></TR><TR><TD CLASS="quote">I think if you pop out the radio just look on the top inside the code should be stuck on by sticker</TD></TR></TABLE><p>NEVER<br>You may find that a prior owner used a Sharpie to mark the code on the radio but no stickers, EVER
1 - 20 of 20 Posts
