Hey All,
I Plan on upgrading the brake system on my '06 XC70 and already have acquired a nice set of used R calipers. Brembo rotors are on order as well as Hawk HPS pads and Techna-Fit SS lines.
The XC presently rides on 18" x 8”"Heico Volution Vs (ET 43) and clearance is not an issue with the current brake setup. What I need is a definitive answer as to the proper width of spacer required for the Heico spokes to clear the R calipers. I've heard from various sources that either 10mm or 15mm on all for axles is the way to go. FWIW, I couldn’t get an answer from Heico N/A.
Anyone out there care to comment? TIA. :)
You don't need a 15mm, the 10mm will be perfect.
