:confused:I have a 1999 C70 convertible. Periodically the speedo will quit working, odometer goes blank, brake, traction control light comes on, then after a while all returns to normal. The car runs perfectly all the time, even when these things are happening. It could happen 5 times a day or once a week, no set pattern.
sounds strange, I think that a dash cluster going bad might cause that problem. It could be a problem in the unit its self and you would have to replace it with a salvage yard cluster. Your C70 would be true mileage unknown "TMU" then. But a cluster should be cheap because one out of a 1998 to 2000 S70, V70 or XC70 would work. I would double check to be sure they others would work but they should. I am not saying thats your problem but it might be?
Bad ABS sensors or control unit will cause the symptoms you describe. You can search other threads in SS for more info.
volvospeed.com will have more members with these cars on there.
BUT
sounds like abs module is on the way out.
midwest-abs.com is a good place to start
Gotta agree with burg_855t
Almost 100% sure its your ABS Module, and Matt's your guy, at Midwest-abs.com
