41 - 60 of 264 Posts
· Registered
Discussion Starter · #41 ·
· Registered
To maintain the SS exhaust tips, just buy SS spray cleaner, same stuff you would use for SS kitchen sinks, etc.,. spray on, let sit, wipe off. If its' bad as yours was, scotchbrite w/ the SS spray cleaner will do it. Very little effort required.
· Registered
Discussion Starter · #43 ·
I'll grab some stainless steel cleaner, thanks for the tip, lol.
In the meantime, how do I get this weird staining off the hatch glass that surrounds the V O L V O letters?
· Registered
Discussion Starter · #45 ·
So my solution for the seats currently is gaffers tape, to stop it from getting worse. However this tape unsticks itself, even though it matches the vinyl perfectly. Does anyone know a good way to get this stuff to stick to the seat? Or should I just look at black duck tape?
· Registered
Discussion Starter · #46 ·
Welp, after trying to fix my AC clutch and lowering the car off the lift, my dumb ass backed it straight into a shop wall.
Messed up the bumper, reflector, and taillight. I have a new taillight on the way already, any ideas on how to pop out this dent in the bumper?
· Registered
Discussion Starter · #48 ·
I don’t have access to one right now, would boiled water work?
· Registered
Try using a bit of white distilled vinegar. Straight up in a spray bottle. Spray on and let sit for 30-45 seconds and then use a microfiber towel.
· Registered
Discussion Starter · #51 ·
So it somehow popped out on it's own in the sunlight, however there's still a noticeable crease, how can I get this out if that's possible?
· Registered
Discussion Starter · #53 · (Edited)
Haha, I got your point as soon as I looked at it. I’m familiar with the old Toyota Camry bumper dent removal, I just didn’t know if a boiling pot of water would hurt the bumper on these cars.
My real concern is that crease, I don’t even know if that will come out.
· Registered
If you get to it sooner than later you MIGHT get lucky. Ehhhh......but more than likely youll see some residual. But then again youll only know once you give it a go.
· Registered
Discussion Starter · #55 · (Edited)
Got the replacement taillight. Got that on, and then to inspect the bumper cover I decided to take it off.
BIG MISTAKE. How screwed am I?
· Registered
Discussion Starter · #56 ·
Okay, so it cleaned up better than expected and the bumper actually fits fine now that it's been refitted.
Is that vent near the dents removable? I'm gonna try to pull some of those out if it is.
· Registered
Discussion Starter · #58 ·
Dang. How fast did you accelerate into the wall??
Should be able to get much of that inner fender damage out if you remove the vent - should be just clipped into the panel
Less than 10 mph if you can believe it. Guess it crumpled easy.
I was thinking about trying a stud welder and trying to pull it out that way? I don't know what tool to use to get it out of the inner fender once I get that vent off.
· Registered
Without sophisticated body shop tools, a slide-hammer is probably the easiest. That is creased pretty sharply, so may not come out clean at all. If the bumper fits properly, may be better to leave it alone. Having said that, just knowing it is there, would bug the crap out of me if it were my car.
· Registered
Sleepless nights even....
