Installed the spoiler last night. There are not any good write-ups of this online, so I’ll detail my process.
First step is to stick a trim removal tool in the middle of the spoiler, between the bottom black part and the top painted or black cover. Remove that, and the two T25 torx, and the three push pin trim clips.
Pull down the inner roof hatch trim, where the rear interior dome lamp is, then loosen the passenger side rear trim. You’ll see the connectors for the washer fluid and third brake lamp, disconnect those.
Afterwards, you’ll need a razor blade to remove the leftover adhesive from the old spoiler. I used a heat gun to help with removal of it.
Looks more like a V50 without any spoiler!
Afterwards, proceed in reverse, and do not overtighten the T25’s used to bolt the spoiler to the glass. They will shear off easily…
End results:
Steering wheel is next up for install, but the blanking plate is stuck at the distribution center over the weekend.
