I have them and I like them. I think they worth it because of the larger rotor size which provides:
- More stopping power with same clamping force. (Yes, the 320mm caliper piston diameter is the same as the 300mm calipers)
- Slightly better heat dissipation.
- Caliper has a different design, looks sturdier, like less prone to flexing from piston pressure.
- Caliper looks better, it fills the wheel better. (I hate brakes that look like this:
If you do the upgrade, that would be the perfect time to also upgrade to stainless steel braided lines and maybe also doing frankenbrakes (rear 302mm)
