Are new bolts required? I just reused mine when I installed adjustable arms on mine, but if they should be replaced, I'll get those swapped outThinking about replacing my rear camber arms at the same time as my wheel bearings, as I'll need an alignment anyways. Does anyone have part numbers for the new bolts required for the rear upper control arms?
I did install those as well. They came with new caliper bolts as well which was nice.Did you install the bearing lock braces as well?
On mine, I removed the old UCA's and then matched the length with the new adjustable ones. Remember to put antiseize on the adjusting threads!........Then, I will be replacing both rear upper control arms with adjustables and shooting for an alignment shortly thereafter. Does anyone have experience with installing these and how to adjust them to the similar length as the originals?
“That” bolt sucks, lol!Got the hub reinstalled last night, and all brake parts installed this morning. Rotors and pads had plenty of meat, but the rotors are loosing inner material via rust (between the vanes). Used plenty of permatex quartz extreme and anti-seize.
After that, I had to get the rear upper control arms in. I applied liberal amounts of anti-seize to both, and got them where they needed to be for a temporary camber level (If I had to guess, -2.0).
But wow, that inner bolt on the passenger side, that was probably the hardest bolt I’ve removed this year. Put up a fight the entire time, even with 1/4 bottle of KROIL on the thing, and then the head tried to slip the socket twice. But it finally came out, got both cleaned up and everything reinstalled.
This has probably been the largest job I’ve done yet on this car, besides the alternator. However, it’s whisper quiet now, I’m so excited to finally be able to enjoy the car without worrying about bearing failure or my tires cupping!!
What brand of hub tool did you use?Got the hub reinstalled last night, and all brake parts installed this morning. Rotors and pads had plenty of meat, but the rotors are loosing inner material via rust (between the vanes). Used plenty of permatex quartz extreme and anti-seize.
What year is your Spitfire? I had a '74 back in the 90's. White with bolt on factory hardtop. One of the favorite cars I have ever owned. I still miss it! I always got the weirdest looks climbing out of it as I am 6'2". It has huge amounts of leg room. Unfortunately the engine blew and I was young and no financial means to deal with it as it was my daily. Thanks for that memory, it is a beauty!In the good news, got this out and driving again after sitting for three years!
The Spitfire is a 77’. It’s been our family project for years but we let it sit for three years. Unfortunately it’s developed several issues even after getting it going again this summer, including a no-start and an unknown coolant leak. We’re weighing options on keeping it versus going farther on a restoration effort, as I also have the C30 and the 850 and they both need attention too!What year is your Spitfire? I had a '74 back in the 90's. White with bolt on factory hardtop. One of the favorite cars I have ever owned. I still miss it! I always got the weirdest looks climbing out of it as I am 6'2". It has huge amounts of leg room. Unfortunately the engine blew and I was young and no financial means to deal with it as it was my daily. Thanks for that memory, it is a beauty!
Could just be dust/dirt/metal hard spot in the pad. When it’s cool….spray the brakes and rotors with high pressure water spray a concentrated blast of brake clean into the pad/rotor interface snd the go for a drive.The Spitfire is a 77’. It’s been our family project for years but we let it sit for three years. Unfortunately it’s developed several issues even after getting it going again this summer, including a no-start and an unknown coolant leak. We’re weighing options on keeping it versus going farther on a restoration effort, as I also have the C30 and the 850 and they both need attention too!
The C30 has a brake squeak, even after disassembling the front left caliper / pads and relubricating them. They are getting slightly low so it’s a possibility the Textar pads that are currently in it have an earlier squeaker than I’m used to. Thinking about going to Akebono‘s / Zimmerman rotors, a setup I’ve used before on my P80 cars.
I also discovered the cupholder rubber inserts have ripped or are not present. Any idea on where to find just the rubber parts for this so I don’t have to destroy the whole plastic cupholder insert?
I have them and I like them. I think they worth it because of the larger rotor size which provides:Those of you who have the 320mm caliper upgrade for the front, do you like it / find it to be worth it? In the works of getting a pair….
wilwoodsThose of you who have the 320mm caliper upgrade for the front, do you like it / find it to be worth it? In the works of getting a pair...
wilwoods
I stuck with my 300mm fronts because it was cheaper and I just got really good pads for it. Then again, I don’t track it, so I’m sure if you did it would be worth it. I'll probably upgrade next time I need pads/rotorsThose of you who have the 320mm caliper upgrade for the front, do you like it / find it to be worth it? In the works of getting a pair...
