anyone know whether it is ok to remove the tiny 10mm bolt that is attached to the brake rotor?
the custom wheel that i got does not have the cavity that will clear that tiny bolt. :(
Yes, not a problem at all. I took mine off when I put my TDR's on.
+1
It only holds the rotor in place until the wheel is installed. That very bolts limits the number of wheels that fits the R. My winter wheels are an example: with the bolt in place, the wheels don't fit for the same reason you describe. Without the bolt, winter wheels fit with just a few millimeters of clearance to the calipers in either direction (inboard/outboard and radially).
