1 - 9 of 9 Posts
I am having trouble getting the timing belt fastened properly, does anyone have a picture of a timing belt diagram?
Thanks!
My friend just contacted me and told me he figured it out, he's gonna tell me what it was tomorrow!
Thanks guys
While on the subject of timing belts...
Do you all usually change the water pump and cam seals when you do the T-belt? My Volvo dealer says they only do them if needed.
Thanks
Stan
I went ahead a changed my water pump due to the fact that it was only an extra 100 or so. It is a pain to get in and out though so you'll have to decide if its worth it depending on its condition. I have a ton of pics on my job here I just started school though so I havn't had time to form it into a post
edit to fix link
Although I'll warn you not to use the harmonic balancer puller that I used it was not the correct tool and it ended up pulling the crank pulley off slightly and I had to hit it back with a dead blow.
This thread. I suppose it would be nice to merge this with the sticky.
That would be great since there is lots of info added, together with blackS40 thread
Also, Dont attempt changing cam seals, its extremely hard for DIY guys. I did mine and i had to order special tools and it was still very tricky job.
1 - 9 of 9 Posts
