Just had my first headlight burnout on my '04 V70, and wanted to use the opportunity to install some Silverstars or something similar. From what I've read in other posts, changing these bulbs myself can be a bit of a trick, and so was wondering if my local dealer will install the new bulbs even though they are not factory?
Just wondering. Thanks in advance -
JCW
Re: Quick Q re: headlights (volvoinva)
It's really not hard to replace them yourself; it's just a bit of a tight fit to get your hands in there. I wouldn't expect the dealer to install them for free unless you were in for other (paid) service and got them to do you a favor.
Sure they'll fit them.
But they'll charge you for the privilege.
Not sure if your bulbs are covered by your warranty in which case you might be able to sweet talk them into doing it free. But I wouldn't count on it.
You can certainly do it yourself, the hardest part is getting the plug off the bulb connectors. they are really tight and there's not much room behind the headlight unit.
I found the easiest way to get the bulbs out was after removing the dust cover to remove completely the spring circlip that holds the bulb in place.
The spring circlip normally clips in place (you will need strong fingers to unclip it) and has 2 prongs that act as a hinge which can then be unhooked fro the back of the headlamp unit.
Then you can remove the bulb and wire connector as a unit, this makes it easier to remove the connector as there'll be more room away from the car.
Rehook the spring circlip, locate the new bulbs, fasten the circlip, push on the connector and replace the dust cap. Job done!
Re: Quick Q re: headlights (hewinutah)
Quote, originally posted by hewinutah »
As far as Silverstars go, they seem to be more show then go.
Check out this site as they compared stock buls to silverstars to HIR bulbs
http://foohbar.com/light_bulb_saga.cfm
Don't know if the HIR's are available for Volvo's What is the light number? 9004, 9002, etc
Modified by hewinutah at 1:17 PM 5-11-2006
The Silverstars available Stateside are different to the ones in Europe.
The US ones have a blue coating to make them look whiter or bluer.
The European Silverstars are clear glass and have a Xenon gas blend which is 50% brighter than regular halogens. Similar to Philips Vision Plus.
Without going for aftermarket HIDs or over-wattage bulbs these are the best replacements we can use.
However, reading up on HIRs has been interesting and they certainly seem to be worth investigating. Anyone know the lifespan of these? They only make them in HB4 and HB3 fittings at the moment, so that means we Volvo drivers can only upgrade our high beams.
I have an 01 so I am not sure if the bulb replacement is the same but it really isn't that difficult. As far as the Silverstars go, save your money. I had my first burn out at or bout 55K, I bought this used so I don't know if they were changed before or not. So I installed the Silverstars. About 10K later I had a bulb burn out. So I replaced both and saved the one good bulb. Again about 10K later another burned bulb, so I used my spare this time. About 5K later it burns another. I was asking the manager at the local Advance Auto about the problems I was having. He said the Silverstars burn hotter and therefore tend to fail sooner than the standard type bulb. I opted for the standard bulb and see no real difference in illumination. My opinion, by a standard bulb and install yourself. The owners manual has a pretty detailed instructions for this. Good Luck
