I was wondering what I need to do to remove the gauge cluster without damaging anything. Does anyone have scans of the VADIS that gives step by step instructions? Any help is great. Thanks!
There is two screws holding the trim on. Located at the top. Pull it out, there are some
spring clips that help hold it in, don't be scared. Then there are two screws located at the bottom of the cluster. Then it should just pull out.
Tools needed T25 driver. Also no more VADIS it is now VIDA.
If you have a fax I can fax you the directions. IM me.
