Will there be a flow difference on our cars between a 3" single pipe from resonator out and 2 1/4 dual both without muffler?<br>DAn
my guess would be minimal...if any, because there is still a lot of stock pipe restriction before that.<p>Dan, why don't you come check out this local exhaust shop...dirt cheap labor!
Re: Question reguarding exhaust diameter (Ride R)
Probably not, it's mostly noise related. That's why the TME system stuck with dual pipes because of noise.
Re: (phuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote"> <br>Dan, why don't you come check out this local exhaust shop...dirt cheap labor!</TD></TR></TABLE><br>MAtt the labor is cheap but the 2 hour travel is expensive! Did you get the resonator installed?<br>DAn
