1 - 2 of 2 Posts
Rear end still leaking a bit so I'm back to thinking about changing the rear end.
If I did a custom rear end, I'd like to go wider on the tire size but the rear spring perch is in the way. Has anyone moved the rear springs inboard roughly an inch to to get them out of the wheelwell?
I might be opening up a huge can of worms with many unintended consequenses.... Any thoughts?
Re: Question on changing the rear suspension geometry (Phattires68)
In my view a full diff swap would be for a car intended for other than daily driver.
That said as you look ahead to your vision of the final product give consideration to making a permanent repair to the leaking diff.
George Dill
1 - 2 of 2 Posts
